spalande
Nacreous
Feb 17, 2014iRule for logging x-forwarded-for header
Getting client request with x-forwarded-for header value. How to log these using irule and using data group for specific client ips
- Magnum_IP
F5 Rocks,
Your request isn't 100% clear but here is something to get started...
Logging
To log out the X-Forwarded-For header
log local0. "X-Forwarded-For: [HTTP::header X-Forwarded-For]"Data Group of IPs
Create a Data Group of type Address (for this example called client_ip_class) and add the IP addresses of interest. Use something like the following to check if an address exists in the Data Group
if { [class match [IP::client_addr] equals client_ip_class] } { The client IP address is in the class file client_ip_class Do something here... }Hope this helps.
