irule for https logging
I am trying to learn iRule and see how best we can use this to setup new applications and also to troubleshoot
For example if i have https traffic via VS and i want to write an irule to log info as below will this irule work??
when SERVER_CONNECTED {
log local0. "Complete connection: Client: [IP::client_addr]:[TCP::client_port]<-> Virtual: [clientside {[IP::local_addr]:[TCP::local_port]}] LTM source [IP::local_addr]:[TCP::local_port] <-> Server: [IP::server_addr]:[TCP::server_port]"
I want to know Client IP, Virtual server IP, SNAT IP, POOL info, server in pool
Thanks for helping
-C
- What_Lies_Bene1
It's mostly good, you are just missing the [clientside {}] for the client details, I've added it like so;when SERVER_CONNECTED { log local0. "Complete connection: Client: [clientside {[IP::client_addr]:[TCP::client_port]}] <-> Virtual: [clientside {[IP::local_addr]]:[TCP::local_port]}] LTM source [IP::local_addr]:[TCP::local_port] <-> Server: [IP::server_addr]:[TCP::server_port]" }
I wonder if you might prefer the VS name to it's IP and port? If so, use '[virtual name]' instead.
