IRULE for HTTP string manipulation
I need help with creating a rule that will look for a key word and then redirect to a different VIP with the rest of the HTTP string intact.
For example,
Header comes with http://www.f5.com/abc/TRIGGER/whatever/whatever.
If the URI has the word TRIGGER
then replace the URL to
http://new.f5.com/abc/TRIGGER/whatever/whatever
Thanks in advance
- Richard__HarlanHistoric F5 Account
I would look at the string command contains.
https://devcentral.f5.com/wiki/iRules.contains.ashx
when HTTP_REQUEST { if {[HTTP::uri] contains "TRIGGER" } { HTTP::redirect "http://new.f5.com/abc/TRIGGER/whatever/whatever" } }You could also look at running HTTP::uri through string tolower to catch up and lower cases requests.
- fhlostonp_19913
Hi Richard, Thanks for the quick reply. The contains will work to identify the string that has TRIGGER in it, but the redirect will need the original string. So I won't know what the whatever/whatever is.
So if the original string is http://www.f5.com/abc/TRIGGER/calendar/render?tab=ncmain_7
then the redirect should be http://new.f5.com/TRIGGER/calendar/render?tab=ncmain_7
- Richard__HarlanHistoric F5 Accountthen all you have to do is update the HTTP::rediret "http://new.f5.com/TRIGGER/calendar/render?tab=ncmain_7"
- nitass
Employee
in case you want to make it a bit more dynamic.
by the way, i think fragment identifier part (starting with hashmark) is not sent to bigip.
Fragment identifier
http://en.wikipedia.org/wiki/Fragment_identifierconfiguration [root@ve11c:Active:In Sync] config tmsh list ltm rule qux ltm rule qux { when RULE_INIT { set static::removal "/abc/" set static::hostname "www.f5.com" set static::newhostname "new.f5.com" } when HTTP_REQUEST { if { [HTTP::host] eq $static::hostname } { HTTP::redirect "http://${static::newhostname}[string map [list $static::removal "/"] [HTTP::uri]]" } } } test [root@ve11c:Active:In Sync] config curl -I http://www.f5.com/abc/TRIGGER/whatever/whatever HTTP/1.0 302 Found Location: http://new.f5.com/TRIGGER/whatever/whatever Server: BigIP Connection: Keep-Alive Content-Length: 0 [root@ve11c:Active:In Sync] config curl -I http://www.f5.com/abc/TRIGGER/calendar/render?tab=ncmain_7 HTTP/1.0 302 Found Location: http://new.f5.com/TRIGGER/calendar/render?tab=ncmain_7 Server: BigIP Connection: Keep-Alive Content-Length: 0 - fhlostonp_19913
Thanks for the reply. Yes I need it more dynamic. The examples I used are not clear. Sorry about that.
Original string http://www.f5.com/abc/TRIGGER/doc/1234
Redirect string http://new.f5.com/abc/TRIGGER/doc/1234
Using the suggestions above, I came up with the following rule. I will try and test.
when RULE_INIT { set static::newhostname "new.f5.com" } when HTTP_REQUEST { if { [HTTP::uri] contains "TRIGGER" }{ HTTP::redirect "http://${static::newhostname}[HTTP::uri]]" } }
