Irule for Data group List to Block specific cookie
Hi. i am wondering if there is any option to create a datagroup (string type) and assign it to an irule which will block the request ( for example response 403) base on the cookie that the client coming with?. example: client is trying to login to the back office system with username and password. in the cookie i can see his login name. i want to block a specific login names . since i have more than 200 logins names to block, i though to create a data group with that will contain the login names i want to block, and to create an i rule which will block the client request base on the cookie
this is an example of a basic login request to the system.
- jgranieri
I am far from a programmer and irule expert but these are basically what you need to do.
Use the event handler When HTTP_REQUEST to capture the header containing the cookie, store it in a variable. Log it or not and then compare it to the string data-group and take an action.
so here is something that you can work off of. You need to pre-configure a pool, a string based data-group. The syntax might be off as I quickly threw it together but you should be able to work off of this and get it going.
when CLIENT_ACCEPTED { log local0. "[IP::client_addr]: HTTP Client Connected" } when HTTP_REQUEST { set Found_Cookie"[HTTP::header value Cookie]" Your choice to log this or not log local0. "Detected Cookie as $Found_Cookie" if { [class match $Found_Cookie contains Cookie_String_Data_Group } { log local0. "Cookie matches data-group and this connection will be rejected" reject } } else { log local0. "Cookie does not match the reject list Allowing connection" pool XYZ }
