js55161_47239's avatar
js55161_47239
Mar 03, 2008
irule conversion from 4.5 to 9.5.3
I am struggling to work out how to convert my exisitng v4.5 irules to 9.5.3.
The following rule is a starter for 10 ...
Version 4.5:
if (http_uri matches_regex "/ShPBranding/BrandEntryServlet") {redirect to "http://www.landg.com"} else {use pool www70.landg.com}
Version 9.5.3:
Help Please!
Many Thanks
  • Aaron
    Thank you very much for this. I will test tomorrow and let you know the out come.
    I will use the the forum you suggest in future.
    cheers
    Jez
