IP Address Pool Management with iRule
IP address pool management is a management of allocating and de-allocating an IP address out of a range of IP addresses or pool. There are several use cases of IP address pool management such as DHCP server and Remote Access Server (RAS). The manager allocates an IP address from the pool when a new connection is established. The manager de-allocates the IP address back to the pool when the connection is torn down.
The following iRule is an example of the IP address pool management with the help of data group and session table. The data group serves as the list of IP address ranges. The session table serves as the place to record the allocation of the IP addresses. The allocation is triggered on RADIUS Accounting Start message. The de-allocation is triggered on RADIUS Accounting Stop message.
Hope this helps...
Cheers,
-joko
=== iRule Start ===
when CLIENT_DATA {
if {[RADIUS::code]==4} {
if {[RADIUS::avp 40]==1} {
set ippool {}
set n [class size CLASS_IP_POOL]
for {set i 0} {$i < $n} {incr i} {
set subnetmask [split [class element -name $i CLASS_IP_POOL] "/"]
set masklen [lindex $subnetmask 1]
if {$masklen < 32} {
set mask 0
for {set i 0} {$i<32} {incr i} {
set mask [expr {$mask << 1}]
if {$masklen > 0} {
incr mask
incr masklen -1
set a [split [lindex $subnetmask 0] "."]
set subnet [expr {([lindex $a 0]<<24)+([lindex $a 1]<<16)+([lindex $a 2]<<8)+[lindex $a 3]}]
set notfoundunused 1
while {$notfoundunused} {
incr subnet
if {[table lookup $subnet.alloc] eq ""} {
set maskxor [expr {$mask^0xffffffff}]
if {[expr {$maskxor&$subnet}] != $maskxor} {
set ippool [expr {($subnet>>24)&0xff}].[expr {($subnet>>16)&0xff}].[expr {($subnet>>8)&0xff}].[expr {$subnet&0xff}]
table set $subnet.alloc 1 3600 3600
set notfoundunused 0
break
if {[table lookup [lindex $subnetmask 0].snat] eq ""} {
set ippool [lindex $subnetmask 0]
break
if {$ippool ne ""} {
table set [RADIUS::avp 8].snat $ippool 900 indef
log local0. "[RADIUS::avp 8] is SNAT-ed to $ippool"
RADIUS::avp replace 8 $ippool ip4
else {
log local0. "Pool exhausted"
elseif {[RADIUS::avp 40]==2} {
set ipori [RADIUS::avp 8].snat
set ippool [table lookup $ipori]
table delete $ipori
set a [split [lindex $ippool 0] "."]
table delete $subnet.alloc
=== iRule End ===
