Geethanjali_321's avatar
Geethanjali_321
Oct 24, 2012
IP address filtering rule does not work
Hi All,
I wanted to create a rule to block all IP addresses except one IP address. So, I gave this rule:
when CLIENT_ACCEPTED {
 if {! [IP::addr [IP::client_addr] equals x.x.x.x] } {
When I try accessing the web page associated with this VS, I am not able to access it from anywhere (that is, am not able to access it even from x.x.x.x which is supposed to have access). Can someone help me with this?
Thanks and Regards,
Geethanjali
  • can you put some log command to see what is going on?
    e.g.
    [root@ve10:Active] config  b virtual bar list
    bvirtual bar {
       snat automap
       pool foo
       destination 172.28.19.79:80
       ip protocol 6
       rules myrule
    [root@ve10:Active] config  b pool foo list
    pool foo {
       members 200.200.200.101:80 {}
    [root@ve10:Active] config  b rule myrule list
    rule myrule {
       if { ! [IP::addr [IP::client_addr] equals 192.168.206.57] } {
          log local0. "Reject [IP::client_addr]:[TCP::client_port] -> [IP::local_addr]:[TCP::local_port]"
          reject
    when SERVER_CONNECTED {
       log local0. "Allow [IP::client_addr]:[TCP::client_port] -> [clientside {IP::local_addr}]:[clientside {TCP::local_port}] -> [IP::remote_addr]:[TCP::remote_port]"
    [root@ve10:Active] config  cat /var/log/ltm
    Oct 25 11:14:38 local/tmm info tmm[7926]: Rule myrule : Reject 172.28.20.11:59191 -> 172.28.19.79:80
    Oct 25 11:14:52 local/tmm info tmm[7926]: Rule myrule : Allow 192.168.206.57:63448 -> 172.28.19.79:80 -> 200.200.200.101:80
  • e.g.
    virtual bar {
       snat automap
       pool foo
       ip protocol 6
       rules myrule
    rule myrule {
       if { ! [class match -- [IP::client_addr] equals ip_class] } {
          reject
    [root@ve10:Active] config  b class ip_class list
    class ip_class {
          host 172.28.19.251
          host 192.168.206.57
    [root@ve10:Active] config  tail -f /var/log/ltm
    Oct 25 22:57:44 local/tmm info tmm[7926]: Rule myrule : Reject 172.28.20.11:59229 -> 172.28.19.79:80
    Oct 25 22:57:53 local/tmm info tmm[7926]: Rule myrule : Allow 192.168.206.57:65000 -> 172.28.19.79:80 -> 200.200.200.101:80
    Oct 25 22:58:12 local/tmm info tmm[7926]: Rule myrule : Allow 172.28.19.251:37085 -> 172.28.19.79:80 -> 200.200.200.101:80
