owen_m_328256
Jul 25, 2017Invalid XML Schema for Generic Scanner
Hi, I'm trying to import some vulnerability data to configure ASM. I downloaded the generic scanner schema so I could be sure I was generating valid XML, however the schema itself seems to be invalid. The following errors appear every time I try and validate it:
Validation 3, 74 s4s-att-not-allowed: Attribute 'maxOccurs' cannot appear in element 'element'
Validation 3, 74 s4s-att-not-allowed: Attribute 'minOccurs' cannot appear in element 'element'.
Validation 67, 20 s4s-elt-invalid-content.1: The content of 'AnonType_scanner_vulnerabilities' is invalid. Element 'sequence' is invalid, misplaced, or occurs too often.
Is this a known issue? Is there another way to validate whether the XML data I generate is correct, short of trial and error?
- samstep
Cirrocumulus
Hi Owen, yes you are right - I have checked myself and indeed XSD does not validate!
I suggest that you raise a support case with F5 regarding this (e-mail: support@)
