frankcheong_304
Jan 26, 2012Intermittent Connection Problem Between Active/Stanby LTM 1600 and a pair of Cisco 2960
I have a pair of LTM 1600 (namely LTM-A & LTM-B) running in active/standby mode and a two pair of Cisco2960 (namely WAN-2960-A, WAN-2960-B, LAN-2960-A & LAN-2960-B). My setup is as below:- Ne...
nitass
Employee
Feb 01, 2012would F5 still needed to participate in VLAN stuff ?if you have dedicated interface for each vlan, vlan tagging is not needed.
I can use switchport mode access in my LAN-2960-A and LAN-2960-B to skip all the VLAN stuff?yes.
since on LTM-A, internal VLAN is untagged, just curious why you need "switchport mode trunk" on LAN-2960-A.by the way, does this make any change about packet drop?
