frankcheong_304
Jan 26, 2012Intermittent Connection Problem Between Active/Stanby LTM 1600 and a pair of Cisco 2960
I have a pair of LTM 1600 (namely LTM-A & LTM-B) running in active/standby mode and a two pair of Cisco2960 (namely WAN-2960-A, WAN-2960-B, LAN-2960-A & LAN-2960-B). My setup is as below:- Ne...
mikand_61525
Jan 29, 2012Instead of using the serial for HA (High Availability) communications one can use one or many networkconnections instead (or using both in case your LTM devices are close to each other).
Regarding VLAN10, sure - depends on how the setup is for External.
Another method (I think) is to use current setup of just VLAN 4092 between your LTMs and setup static routing. But in that I case I dunno what will happen if a packet is sent to the device which is currently set in passive mode (perhaps im confusing this with how HSRP/VRRP works where the passive device turns into a L2 device so the L3 stuff is performed at the active unit).
