frankcheong_304
Jan 26, 2012Intermittent Connection Problem Between Active/Stanby LTM 1600 and a pair of Cisco 2960
I have a pair of LTM 1600 (namely LTM-A & LTM-B) running in active/standby mode and a two pair of Cisco2960 (namely WAN-2960-A, WAN-2960-B, LAN-2960-A & LAN-2960-B). My setup is as below:- Ne...
frankcheong_304
Jan 29, 2012What do you mean by using VLAN 4092 AS HA-Network between the LTM?
BTW, What about VLAN 10? Should I also include VlAN 10 into the failover Fibre Trunk?
