frankcheong_304
Jan 26, 2012Intermittent Connection Problem Between Active/Stanby LTM 1600 and a pair of Cisco 2960
I have a pair of LTM 1600 (namely LTM-A & LTM-B) running in active/standby mode and a two pair of Cisco2960 (namely WAN-2960-A, WAN-2960-B, LAN-2960-A & LAN-2960-B). My setup is as below:- Ne...
mikand_61525
Jan 27, 2012Yes.
Do you use your VLAN4092 as HA-network between the LTM's?
