frankcheong_304
Jan 26, 2012Intermittent Connection Problem Between Active/Stanby LTM 1600 and a pair of Cisco 2960
I have a pair of LTM 1600 (namely LTM-A & LTM-B) running in active/standby mode and a two pair of Cisco2960 (namely WAN-2960-A, WAN-2960-B, LAN-2960-A & LAN-2960-B). My setup is as below:- Ne...
frankcheong_304
Jan 27, 2012That means the failover (Fibre) VLAN also need to use VLAN 4093 in addition to its own VLAN 4092, right?
For WAN-Switches, I also would like to bond it but would like to fix all the problem first.
