Jahmedj's avatar
Jahmedj
Feb 16, 2022
intelligent load balancing issue
I have an https client connections on F5 LB. All client traffic uses default https port 443. the VIP should forward the traffic to a different ports in same pool of two server. The idea is request from https://jahmedj.com/abc must go to server1 on port 7901 and https://jahmedj.com/xyz must go to another server on port 7902.
i craeted policy and applied but not working, looking for alternate method to achive this LB.
    • Jahmedj's avatar
      Jahmedj
      dear Vaibhav,
      I will try and and update you.
    • Jahmedj's avatar
      Jahmedj
      Dear Vaibhav,
      No, it didn't work.
      All traffic perhaps going to forst pool only.
      any other clue
      • VernonWells's avatar
        VernonWells
        Jahmedj, following up on my comment below, you can use a Local Traffic Policy.  I have a setup where any uri-path equal to /abc or starting with /abc/ goes to a pool using port 8080.  Any uri-path equal to /xyz or startin with /xzy/ goes to a pool using port 8081.  The node (server) set in each pool is the same.  Here are the relevant snippets:
        ltm virtual vs-http-01 {
            destination 10.1.10.100:http
            policies {
                pool-steer-by-uri-path { }
            pool pool-8080
            profiles {
                f5-tcp-progressive { }
                http { }
            source-address-translation {
                type automap
            translate-address enabled
            translate-port enabled
            vlans {
                clients
            vlans-enabled
        ltm pool pool-8080 {
            members {
                server01:webcache {
                    address 10.1.20.20
                    session monitor-enabled
                    state up
            monitor http
        ltm pool pool-8081 {
            members {
                server01:tproxy {
                    address 10.1.20.20
                    state up
            monitor http
        ltm policy pool-steer-by-uri-path {
            controls { forwarding }
            requires { http }
            rules {
                "uri path abc exact" {
                    actions {
                        0 {
                            forward
                            select
                            pool pool-8080
                    conditions {
                        0 {
                            http-uri
                            path
                            values { /abc }
                "uri path abc starts_with" {
                    actions {
                        0 {
                            forward
                            select
                            pool pool-8080
                    conditions {
                        0 {
                            http-uri
                            path
                            starts-with
                            values { /abc/ }
                    ordinal 1
                "uri path xyz exact" {
                    actions {
                        0 {
                            forward
                            select
                            pool pool-8081
                    conditions {
                        0 {
                            http-uri
                            path
                            values { /xyz }
                    ordinal 2
                "uri path xyz starts_with" {
                    actions {
                        0 {
                            forward
                            select
                            pool pool-8081
                    conditions {
                        0 {
                            http-uri
                            path
                            starts-with
                            values { /xyz/ }
                    ordinal 3
            strategy first-match
        This particular code does not strip the leading part of the URI path.  Thus, if one goes to:
        http://10.1.10.100/abc/def/file.html
        then that is the same path (i.e., /abc/def/file.html) that would be sent to server01 port 8080, rather than, say, /def/file.html.  The latter is possible, as well, if desired.
  • Jahmedj, the subtlety in the link that vaibhav provided is that there are two pools.  In general, a "node" on a BIG-IP corresponds to a target IP address of a forwarding target.  A "pool member" is the combination of a "node" and a layer4 port.  A "pool" consists of a collection of zero or more "pool members".  The two pools would have members that have the same node IPs, but different ports, as in:
    ltm node server01 { address 10.10.1.5 }
    ltm node server02 { address 10.10.1.6 }
    ltm pool target_7901 {
       members { server01:7901 server02:7901 }
    ltm pool target_7902 {
       members { server01:7902 server02:7902 }
    Your Local Traffic Policy would then target the corresponding pool based on the URI path match.
  • Have a look at this one and let me know what out of this doesnt work for you and we can modify this,  I tested this one below and it works. Ignore the wildcard as thats not your case
    And what modifications are needed ... i am yet to explore policies equivalent of I-rule but i can try modifying the Irule
    ltm rule pool_URI-redirection {
    switch -glob [HTTP::uri] {
    "/URI1/v1.0/RMAOrders*" {
    pool pool_pool_5101
    "/URI1/v1.0/miscIssues*" {
    pool pool_pool_5085
    "/URI1/v1.0/miscReceipts*" {
    pool pool_pool_5084
    "/URI1/v1.0/pickReleaseOrdersAck*" {
    pool pool_pool_5083
    "/URI1/v1.0/poReceipt*" {
    pool pool_pool_5081
    "/URI1/v1.0/purchaseOrdersAck*" {
    pool pool_pool_5079
    "/URI1/v1.0/purchaseOrders*" {
    pool pool_pool_5078
    "/URI1/v1.0/RMAReceipts*" {
    pool pool_pool_5111
    "/URI1/v1.0/shipConfirmOrders*" {
    pool pool_pool_5076
    "/URI1/v1.0/subInvTransfers*" {
    pool pool_pool_5077
    "/URI1/v1.0/pickReleaseOrders*" {
    pool pool_pool_5082
    "/anotherURI/Endpoint*" {
    pool pool_pool_5115
