Technological_S
Sep 21, 2009inserting client ip address into DATA when protoco is not HTTP and using SNAT
Hi Devcentral.
I need insert de client IP because I using SNAT, but I don`t user HTTP protocol, I need insert de client IP into TCP DATA paquet.
Any sugestion.
Best regards
Carlos Fontecha.
- hoolio
Hi Carlos,
You could potentially collect and modify the TCP payload using TCP::collect and TCP::payload. You can check the TCP wiki page for details on these commands (Click here).
Aaron - Technological_S
Thansk Aaron.
I create this iRule, (first aproximation).
rule proxy-hmig
when CLIENT_ACCEPTED
set ORIG_Request [TCP::collect]
set ORIG_CLIENT_IP [IP::client_addr]
when CLIENT_DATA
set ORIG_Request [string range $ORIG_Request 0 $ORIG_CLIENT_IP]
TCP::release
Regards
Carlos Fontecha.
