Bob_Vance_75936's avatar
Bob_Vance_75936
15 years ago
INET port exhaustion and ip forwarding VIP
Hello,
Every now and then we will have an issue with inet port exhaustion being logged for DNS traffic passing thru the LTM using the ip forwarding VIP:
local/tmm crit tmm[9177]: 01010201:2: Inet port exhaustion on 10.1.1.7 to 10.1.2.20:53 (proto 17)
There are a lot of connections being used but not enough to actual exhaust all possible ports. Also, since this is using the ip forwarding VIP I would think that the ports would be retained and not be translated. However, when I check, I notice that more often than not the source port is translated by the LTM.
VIRTUAL any <-> NODE 10.1.2.20:domain TYPE any 1/0
CLIENTSIDE 10.1.1.7:32786 <-> 10.1.2.20:domain
SERVERSIDE 10.1.1.7:32789 <-> 10.1.2.20:domain
PROTOCOL udp UNIT 1 IDLE 287 (300) LASTHOP vlan1625 00:50:56:93:01:46
Could a massive influx of DNS queries cause inet port exhaustion if they are actually being translated by the ipforwarding VIP? And why would the ip forwarding VIP translate the src ports?
  • hoolio's avatar
    hoolio
    Hi Bob,
    We discussed optimizing and UDP DNS virtual server configurations in this thread:
    http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/52/aft/1168069/showtab/groupforums/Default.aspx
    If you follow those tips you should be able to greatly reduce the time that connections are kept for.
    Aaron
  • Thanks hoolio. Very interesting info in that thread.
    Does anyone have a link or info on how the LTM controls the port translation across a VIP? Below is the ip forwarding VIP and I am searching for why the LTM would proxy this connection and change the source ports.
    virtual ip_forwarding {
    enable
    limit 0
    rate class none
    mirror disable
    translate address disable
    translate service disable
    srcport preserve
    fastl4
    snat none
    cmp enable
    cmp processor none
    lasthop pool none
    snatpool none
    pool none
    fallback persist none
    destination any:any
    mask 0.0.0.0
    ip protocol any
    partition Common
    rules none
    httpclass none
    persist none
    auth none
    clone pools none
    profiles fastL4 {
    all
    traffic classes none
    vlans none disable
  • hoolio's avatar
    hoolio
    Hi Bob,
    See SOL11003 for some details on this:
    http://support.f5.com/kb/en-us/solutions/public/11000/000/sol11003.html
    Aaron
  • Hoolio: Do you think "srcport preserve strict" might help here? Sounds like the LTM thinks that (for some reason) the source port is already being used in error; i think "strict" will force it to not translate, period, whereas "srcport preserve" does it only if it's not tracking anything it thinks is conflicting.
  • hoolio's avatar
    hoolio
    Is it a problem if the source port gets translated? If so, I think reducing the idle timeout (to immediate?) for UDP would alleviate the port reuse. Regardless it would make sense to really trim down the idle timeout for DNS traffic.
    Aaron
  • My $.02: I wouldn't use preserve strict here, as it only really applies to UDP virtual servers (See the warning at the bottom of SOL8227) and DNS can use TCP as well.
    -Matt
  • hoolio's avatar
    hoolio
    Yeah, that's another reason separate virtual servers for TCP and UDP make a lot of sense for DNS. I think we covered this fairly well in the past thread I linked to above.
    Aaron
