Jaspreetgurm's avatar
Jaspreetgurm
4 years ago
images is not loading correctly
Images is not loading the page sitting behind F5 LTM
see error below.
Virtual server is setup with 2 pool memebers.
SSL offloading profile is setup on LTM
below irule also configured.
 if { [string tolower [HTTP::uri]] starts_with "/gamification" } {
  HTTP::uri [string map -nocase {"/gamification" ""} [HTTP::uri]]
can someone help on this.
  • Can you share the request and response headers on the request that fails so we have a little more to information for troubleshooting, please?
  • xuwen's avatar
    xuwen
    string map will replace all the string if it contains "/gamification", you need use regsub to replace first /gamification:
    11 % set uri "/gamification/gamification_uploads/header.jpg"
    (bin) 12 % string map -nocase {"/gamification" ""} $uri
    _uploads/header.jpg
    (bin) 13 % set uri
    (bin) 14 % regsub -nocase "/gamification" $uri "" new_uri
    1
    (bin) 15 % set new_uri
  • You can simply tweak this part, so it matches your requirement.
    HTTP::uri [string map -nocase {"/gamification/" "/"} [HTTP::uri]]
    Explanation:
    set newuri [string map -nocase {"/gamification" ""} $uri]
    Will give you "_uploads/header.jpg"
    But being specific like below,
    set newuri [string map -nocase {"/gamification/" "/"} $uri]
    Will give you "/gamification_uploads/header.jpg"
    Hope it explains.
