IE issue with cookie persistence.
I have 12 hour cookie persistence enable, it works fine with other browser except IE. Users are complaining about getting logged off randomly. Is there any fix for this?
{External VIP} --> {Internal VIP} --> {Pool Members}. Cookie persistence is applied to the internal VIP.
- nitass
Employee
so, what is the problem? doesn't browser send the cookie or does bigip send traffic to the server not matching the cookie?
- Nitin2014_16246
IE doesnt show the cookie expiry time. Users on IE get logged off randomly. - Brad_Parker
Cirrus
Are you sending the cookie with ever request? It could be possible that the cookie is reaching its expiration mid session because it was first set in a previous session and you're not sending the cookie with each request.
- nitass_89166
Noctilucent
- Nitin2014_16246
Cirrus
- Brad_Parker
Cirrus
If a user has their privacy settings set to "HIGH" in IE it requires a P3P compact policy header to accept file cookies. It you used a session cookie, IE users would have that issue, but it also wouldn't have a timeout value. It would require the browser to be closed. If you truly want to timeout your persistence cookies, I would recommend looking into how Facebook and Google get around the P3P policy. I'm not going to link to it, but a simple search should find the info required.
- Nitin2014_16246
Bug: 397337 : BIG-IP should send cookie always in response especially if cookie expiration is in play.
Solution: Upgrade code to 11.3
- Nitin2014_16246
- Nitin2014_16246
