Derek_21893's avatar
Derek_21893
Aug 06, 2009
iControl SDK v9.4.0 wrong about temperatures
Hi, I've noticed that for CPU temperatures in iControl, the SDK docs say that System.CPUMetricType.CPU_TEMPERATURE is "The current temperature in degrees farenheit". This is either wrong, or my F5 LTM has a refrigerant cooling system as the cpu with index 1 is below freezing:
***** CPU *****
CPU_INDEX : 1
CPU_TEMPERATURE : 30
CPU_FAN_SPEED : 7336
CPU_INDEX : 2
CPU_TEMPERATURE : 37
Certainly it was meant to say "Celsius" instead of "Farenheit"?
This is also true of System.PlatformTemperatures as well, although the SDK docs don't even tell you if you should expect Celsius or Farenheit.
Thanks,
-Derek
  • FYI, I've verified that these errors exist in the 9.6.0 and 10.0.0 SDK documentation.
    Thanks,
    -Derek
  • Derek,
    I suggest you raise this as a support issue with F5 as a bug in iControl documentation. You need to go through the official support channel to get their attention...
    Sam
