Maximilien_Rieh
Oct 22, 2014iControl Rest API: Node description reliability problems
We're orchestrating f5 loadbalancers through the iControl rest API and we seem to be running into strange behaviour.
A GET against
/mgmt/tm/ltm/node/NODENAME returns information about that node.
The JSON usually looks like this (shortened):
'kind': 'tm:ltm:node:nodestate',
'name': '/partition_we_use/hostname',
'state': 'down',
'session': 'user-disabled',
But sometimes the
session key is just missing. I couldn't find an API contract but it seems wrong to me to just randomly leave a field out of the response.
Any ideas what might be wrong? Colleagues have seen it show up occasionally, and I was not able to reproduce it yet (and it's only affecting some nodes).
- Mattias_Anderss
I've tried to reproduce this but haven't seen the session key missing. What version are you on? You might try to add "_return_fields" to the GET request to fields you wish to retrive? That might do the trick?
- Mattias_Anderss
Sorry, not "_return_fields" but "$select". For example: /mgmt/tm/ltm/node?ver=11.5.0&$select=session,name { "kind": "tm:ltm:node:nodecollectionstate", "selfLink": "https://localhost/mgmt/tm/ltm/node?$select=session%2Cname&expandSubcollections=true&ver=11.5.0", "items": [ { "name": "node1", "session": "monitor-enabled" }]}
