zbirmingham's avatar
zbirmingham
Mar 27, 2008
iControl Powershell Issues
I can't enable or disable nodes through the PowerShell iControl Snap-in. I'm able to successfully query a node via the Get-F5.LTMNodeAddress command, but when I use the Disable or Enable command and pass in a Node I receive the following error: You must specify either the Node or NodeItem parameter.
I attached a screenshot of the commands I'm passing. Can anyone help?
  • You are right. I just dug into the source and found the issue. I've updated the PowerShell downloads on DevCentral with this fix. You can download the installer ( Click here ) again if you want or you can just download the binary package ( Click here) and overwrite the .dll's on your system.
    Sorry for the mixup and hopefully this get's things working for you. Let me know if not...
    -Joe
