Dave_Wiley
Jul 02, 2008iControl method for retrieving "b conn show"
Good morning!
What is the iControl method/structure necessary to pull information that is contained in the "b conn show" CLI command?
Thanks!
Dave
- Currently there is no equivalent. In v4.x we had the Connections interface but it was found that returning the possible millions of records within a SOAP call was not a, er, "optimal" solution. The process of building a viable "paging" system for this interface has been in PD for a while but it has not been released.
-Joe - JRahm
Admin
I wish the LTM had a netflow/sFlow collector so the connection table wasn't the only way to utilize that data. - dennypayne
Employee
I'm reviving this topic in the hope that someone might have an idea how I can use iControl to retrieve current connection age status for a virtual server, which can normally be shown with b conn age show command on the CLI. Thoughts?
Denny
