Vincent_Li_9688's avatar
Vincent_Li_9688
Historic F5 Account
Mar 12, 2013
iControl Java help on certificate_import_from_pem
I am totally Java and iControl Java API newbie, and this is my first Java code adopted from devcental, I am trying to import certificate use certificate_import_from_pem, I got an highlight error in Eclipse, I think i am not getting the object definition/declaration from iControl class correct, any tip ?
public class KeyCertificate {
public iControl.Interfaces m_interfaces = new iControl.Interfaces();
public void usage()
System.out.println("Usage: SystemInfo hostname username password");
public void Run(String [] args) throws Exception
if ( args.length < 3 )
usage();
else
String host = args[0];
String user = args[1];
String pass = args[2];
boolean bInit = m_interfaces.initialize(host, user, pass);
if ( bInit )
addCertificates();
///////////////////////////////////////// private method for the cert //////////////////////////////////////////////////////////////
private void addCertificates()
throws Exception
String[] certs = new String[1];
String names = "test_cert";
String mode = "ManagementKeyCertificateManagementModeType.MANAGEMENT_MODE_DEFAULT"; ///////////////here seems not right
iControl.ManagementKeyCertificateBindingStub certstub =
m_interfaces.getManagementKeyCertificate();
certs[0] = "-----BEGIN CERTIFICATE-----\n" +
"MIICbjCCAdcCBgEKka0UIzANBgkqhkiG9w0BAQsFADB9MQswCQYDVQQGEwJBVTEM\n" +
"MAoGA1UECBMDTlNXMQ8wDQYDVQQHEwZTeWRuZXkxGTAXBgNVBAoTEHBpbXBqaW1t\n" +
"eS5hdS5jb20xGTAXBgNVBAsTEHBpbXBqaW1teS5hdS5jb20xGTAXBgNVBAMTEHBp\n" +
"bXBqaW1teS5hdS5jb20wHhcNMDYwNDEzMDUxNTM0WhcNMTEwNDEzMDUxNTM5WjB9\n" +
"MQswCQYDVQQGEwJBVTEMMAoGA1UECBMDTlNXMQ8wDQYDVQQHEwZTeWRuZXkxGTAX\n" +
"BgNVBAoTEHBpbXBqaW1teS5hdS5jb20xGTAXBgNVBAsTEHBpbXBqaW1teS5hdS5j\n" +
"b20xGTAXBgNVBAMTEHBpbXBqaW1teS5hdS5jb20wgZ8wDQYJKoZIhvcNAQEBBQAD\n" +
"gY0AMIGJAoGBANgR1vv312gokkkQzotDS1fqXV57HcgVeMA/dHetaqbWNFnvF6pi\n" +
"+U+d85sh9ONwLAv8vrU58yUZFnEcwc1mp6P9O8MI6pAyCYACpdnVGkzQm7uDiFLr\n" +
"aKZiaMI3s4K2WA7kLR6T53oZlGx8LFIkU2rHygk59BW63zOiveQKaRHNAgMBAAEw\n" +
"DQYJKoZIhvcNAQELBQADgYEAaHGGQOHhf7oRhf2bZWcPH0wI/a6yJQ0zxegAnx9O\n" +
"1S8NeE/Cc+T+scQ2t3H8/wH/bxNlXdYVgo/F9oc7XNQ/KO6ainQbaH37irG2WBvM\n" +
"69N+ZA8xGS9rPen4za7YqNzshDBa1ZOIjh5uHw2UCj5C/vwhGefVaeTxkmXHtQVt\n" +
"BHY=\n" +
"-----END CERTIFICATE-----";
certstub.certificate_import_from_pem(mode, names, certs, true); ///////////////////////got an error here in Elicpse
* @param args
public static void main(String[] args) {
try
KeyCertificate kc = new KeyCertificate();
kc.Run(args);
catch(Exception ex)
ex.printStackTrace(System.out);
  • 1. "names" should be an array and not a string - read the API documentation: https://devcentral.f5.com/wiki/iControl.Management__KeyCertificate__certificate_import_from_pem.ashx
    2. "modes" is not a string either :-) documentation in the wiki link above
    3. learn Java before attempting to program in that language (or choose a programming language you know best - iControl works with many languages)
  • Vincent_Li_9688's avatar
    Vincent_Li_9688
    Historic F5 Account
    FYI, I end up with following java code to make it work:
    import java.io.*;
    import java.util.Scanner;
    public void usage()
    System.out.println("Usage: KeyCertificate hostname username password");
    usage();
    else
    if ( bInit )
    addCertificates();
    private String readFile(String pathname) throws IOException {
    File file = new File(pathname);
    StringBuilder fileContents = new StringBuilder((int)file.length());
    Scanner scanner = new Scanner(file);
    String lineSeparator = System.getProperty("line.separator");
    try {
    while(scanner.hasNextLine()) {
    fileContents.append(scanner.nextLine() + lineSeparator);
    return fileContents.toString();
    } finally {
    scanner.close();
    throws Exception
    String[] keys = new String[1];
    String[] key_ids = null;
    key_ids = new String[]{"vli_self_server_key"};
    String[] cert_ids = null;
    cert_ids = new String[]{"vli_self_server_cert"};
    iControl.ManagementKeyCertificateBindingStub certstub = m_interfaces.getManagementKeyCertificate();
    iControl.ManagementKeyCertificateManagementModeType mode = iControl.ManagementKeyCertificateManagementModeType.MANAGEMENT_MODE_DEFAULT;
    keys[0] = readFile("C:\\Users\\vli\\iControl-java\\vli_self_server.key");
    certs[0] = readFile("C:\\Users\\vli\\iControl-java\\vli_self_server.crt");
    try {
    certstub.key_delete(mode, key_ids);
    certstub.certificate_delete(mode, cert_ids);
    }catch (Exception e) {
    System.out.println("certificate and key not exist");
    certstub.certificate_import_from_pem(mode, cert_ids, certs, true);
    certstub.key_import_from_pem(mode, key_ids, keys, true);
    certstub.certificate_bind(mode, cert_ids, key_ids);
    System.out.println("certificate and key import succeeded!");
    * @param args
    try
    kc.Run(args);
    catch(Exception ex)
