player_72606
Sep 16, 2010icontrol as external monitor
Hi all
new to icontrol , please be gentle... :-)
a security policy requires that all VS that are offline or down should not respond to echo requests when it's pool members are down.
i do know that ARP must be disabled in order to achieve this but i need also an external monitor which be done with icontrol
please correct if i'm wrong and if you have any insights about this, feel free to post
has anyone done it?
- samstep
Cirrocumulus
This is a very convoluted and time-consuming way of achieving your goal, but I think it is do-able.
Essentially you will need to check the status of the Virtual Address corresponding to the Virtual Server you are monitoring and disable ARP using set_arp_state() method:
http://devcentral.f5.com/wiki/default.aspx/iControl/LocalLB__VirtualAddress__set_arp_state.html
It might be easier to just disable ICMP completely using packet filters if it is OK with your security policy....
