geoffrey_112372
Jan 21, 2009iControl and ratio load balancing
I have a question about iControl and ratio load balancing, I hope you could help me
I want to know what is the impact on local traffic manager system if a script change frequently ratio values with iControl?
thanks
- The impact will be the same as if you were making the changes through the GUI or the CLI. As long as you aren't doing something crazy like 1000 requests/sec, I wouldn't be concerned about it.
At what rate are you thinking you will be making changes?
-Joe - geoffrey_112372
i have not defined yet the rate of changes but I think it will be like 100 ratio values change every 5 minutes balanced between members of different pool.
Is there any chance I get a system failure after a long period? - That should not cause any problems.
-Joe
