luciano_dias_17
Oct 01, 2016ICMP Monitor logical inverted
Hi, I would like to create a ICMP monitor for a node that while the ICMP echo ok the node stays down and when ICMP fail the node came up. How to do this ?
- Vijay_E
Cirrus
There isn't a "Reverse" option for ICMP monitor. I think this can't be done with existing settings. You may be able to achieve this with iRule but is it really worth the complexity and is it possible to explore TCP monitor options ?
