JMeyer_44695's avatar
JMeyer_44695
Dec 20, 2013
iApp template for Sockets/Host Sockets?
Is there an iApp template for Sockets/Host Sockets? The application does not use HTTP, but listens on arbitrary ports. I just want to forward traffic to these ports.
  • Sagen_80793's avatar
    Sagen_80793
    Historic F5 Account
    JMeyer,
    Thank you for the suggestion. We currently do not have an iApp published that does simple load balancing of traffic while listening on an arbitrary port.
    Do you have any additional requirements you would want to see? Is this for TCP or UDP traffic? Would you want to be able to adjust the TCP timeout for the client and server side?
    • Sagen
