iApp for remote logging (f5.remote.logging.v0.1.0) issues with import on 11.5.1
Guys
Am trying to import the f5.remote.logging.v0.1.0 iApp template and get the following error message
any idea what the issue could be?
Cheers per
Loading configuration... /tmp/upload_template.tmpl 01070712:3: ERROR app_template - /Common/f5.remote_logging.v0.1.0 definition: /Common/f5.remote_logging.v0.1.0 definition:1: error: [script "f5.iapp.1.1.1.cli" included from "APP_TMPL_/Common/f5.remote_logging.v0.1.0_definition" not found][tmsh::include f5.iapp.1.1.1.cli] /Common/f5.remote_logging.v0.1.0 definition:2: error: [undefined procedure: iapp_template][iapp_template start] /Common/f5.remote_logging.v0.1.0 definition:5: error: [undefined procedure: iapp_is][iapp_is ::options__advanced_mode "yes"] /Common/f5.remote_logging.v0.1.0 definition:37: error: [undefined procedure: iapp_conf][iapp_conf create sys log-config \ destination remote-high-speed-log ${app}_hsldest \ pool-name [subst $logging_pool($new_pool)]] Unexpected Error: Loading configuration process failed.
- mikeshimkus_111Historic F5 Account
Hi, the iApp was referencing a cli script that isn't present on a BIG-IP where it hasn't been previously imported. The iApp template has been corrected and reposted to DevCentral.
Mike
- Per_Bo_Nielsen1Historic F5 AccountHi Mike Would you have the url, i cant only find the old version 1.0 iApp ?
