F5_waqarali_196
Apr 09, 2015i want to run tcpdump on bigip active device in HA, between internal sever and bigip internal interface.
i want to run tcpdump on bigip active device in HA, between internal sever and bigip internal interface. tel me should i use internal interface self ip address or floating ip address. thanks.
- amolari
you should use the floating, in normal SNAT-Automap condition (traffic sent first with floating IP as source, if too many connections, SelfIP is used additionally).
Self IP will be the source IP for health monitoring traffic
- amolari
the health monitor is always using self IP addresses. This of all cluster devices (not dependent of active or standby state)
