Sumanta_88744's avatar
Jun 24, 2016
i Rule for extracting specific value from http payload and using it for UIE persistence
Hi Experts
What would be the iRule code for identifying and extracting a particular field from http payload and using it for creating UIE persistence?
  http.request.line == "X-3GPP-Intended-Identity: \"sip:[email protected]\"\x0d\x0a".
The above can be used as a filter for checking sessions from pcap files in Wireshark.
The below value will change for each new session from a new client and based on it, the F5 will create persistence table.
 "[email protected]"
  • Hi, the "X-3GPP-Intended-Identity" is a request header, isn't?
    If so, I would try like this:
        if { [HTTP::header exists "X-3GPP-Intended-Identity"] } {
            regexp {sip:(.+@\w*\.[\w|-]*\.[\w|-]*)} [HTTP::header value "X-3GPP-Intended-Identity"] dummy key
            if { [info exists key] } {
                persist uie $key
            unset -nocomplain dummy key
    or this (without costly regex):
            set values [split [lindex [split [HTTP::header value "X-3GPP-Intended-Identity"] :] 1] .]
            set key [concat [lindex $values 0].[lindex $values 1].[lindex $values 2]]
            if { $key ne "" } {
                persist uie $key
            unset values key
    I hope it helps.
