Vim_113268's avatar
Vim_113268
Nov 28, 2009
I need Help - Need to create Redirect
I need to Implement an iRule on the ABC VIP so that any attempt to hit
aaa.bbb.com/starss on this VIP will redirect back to / (ex. aaa.bbb.com/ )
I want this to happen for both Http and https requests.
please advise ASAP.
Thanks.
  • Below is the exact example:
    Redirect eigther http or https for
    one.test.com/xxx
    to
    https://one.test.com/
  • Here is an example
        if { ([HTTP::host] eq "one.test.com" ) and ([HTTP::uri] eq "/xxx" ) } {
            HTTP::redirect "https://one.test.com/"
    If you are trying to redirect HTTPS to another HTTPS please keep inmind that it won't work unless the SSL is terminated at the F5.
    I hope this helps.
    Bhattman
  • BATTMAN
    i am currently using following:
    if { [HTTP::uri] equals "/xxx" } {
    HTTP::redirect "https://abc.xyz.com/"
    will it work?
