I did not fine connection mirroring check box.
In the url "https://support.f5.com/kb/en-us/solutions/public/13000/400/sol13478.html3"
Follow the title "Configuring connection mirroring for a virtual server" I go to "Local Traffic > Virtual Servers." But i did not find the Connection Mirroring check box. how can i enable the funcation? thanks a lot!!
- Ed_Summers
What version are you running?
I don't recall if the GUI adjusts based on other config settings, but do you have a sync-failover group configured and working?
GUI is in fact adapting to your service cluster configuration, so if you don't have a cluster already configured you will not see the connection mirroring parameter.
