Brian_Kenworthy's avatar
Brian_Kenworthy
Apr 13, 2007
https to http pool rule, need help asap
Hi all, I have created an SSL proxy which forwards to virtual server which is pointing to a rule redirect the https request to certain pools but it is not working. Is it possible to forward the https request to an http pool?
Here is the rule:
if (http_uri matches_regex "/TestProxy*") {
use pool _HTTP
else if (http_uri matches_regex "/console*" or http_uri matches_regex "/testconsole*") {
use pool _AdminSrvr_HTTP
else {
use pool _HTTPS
The proxy is setup is this
proxy server - 10.xx.xx.xx:443
destination host 10.xx.xx.xx:443 (SSL/ServerSSL)
Thanks in advance for any help! I'm not sure what I am doing wrong.
Thanks,
Brian
