Rajesh_07_16489
Jan 15, 2015Https Monitor
How HTTPS Monitor works without associating Certificate and Key on it. But, there is a value (Default:+SHA,+3DES,+KEDH) at "Cipher List". Is that not necessary to associate certificates on https Monitors? If so, how SSL handshake is happening from HTTPS monitor to Server?
Your help is appreciated.
- Michael_Jenkins
If you look on the monitor page, and change the
dropdown fromConfiguration
toBasic
, you can set the client certificate and key in the newly visible fields.Advanced
