Josh_41258
Feb 28, 2013HTTPS Monitor Help
I'm having trouble getting a HTTPS monitor to work correctly (turn green). When I use curl, I see:
> GET / HTTP/1.1
> Host: 172.26.96.105
> Accept: */*
< HTTP/1.1 200 OK
< Date: Thu, 28 Feb 2013 19:50:07 GMT
< Connection: Keep-Alive
< Content-Type: text/html
< Content-Length: 3514
I have tried every variation of "Send String" that I can think of with no success. Any suggestions on a valid send string to use for this monitor?
- afedden_1985
Cirrus
we use a version of this, the parent monitor type must be https, (probe type)
HEAD /thePAGEyourLOOKINGfor/heartbeat.html HTTP/1.1\r\nHost: HOSTNAME.domainname.com\r\nConnection: close\r\n\r\n
use the page your looking for in place of mine and add the correct host name (vip DNS name) if the server expects one
don't forget to set the proper return code 200 if thats what you expect
hope it works it works in our shop - Josh_41258
So, just "200 OK" in the "Receive String" box?
- afedden_1985
Cirrus
correct just enter 200 in the receive string box - afedden_1985
Cirrus
correct just enter 200 in the receive string box - Josh_41258
Thanks, your string did the trick!
