cvrnr_18603
May 01, 2009https and ssh unavailbe for few minutes
My bigip system was unable to load https and connect through jhttps for few seconds although the traffic is paassing through the bigip fine
i saw these logs in the system
Fri May 1 11:40:01 EDT 2009 f5-5110-a bcm56xxd[1432] 012c0011 Trouble getting snmpIfHolDiscards stats: unit=1, port=17 bs_stats.c235
Fri May 1 11:40:01 EDT 2009 f5-5110-a bcm56xxd[1432] 012c0010 Trouble reading stats from interface=1.1 bsx.c2324
Fri May 1 11:40:01 EDT 2009 f5-5110-a bcm56xxd[1432] 012c0007 Trouble creating interface query reply bsx_mcpmsg.c1612
Fri May 1 11:50:10 EDT 2009 f5-5110-a bcm56xxd[1432] 012c0011 Trouble getting snmpIfHolDiscards stats: unit=1, port=17 bs_stats.c235
Fri May 1 11:50:10 EDT 2009 f5-5110-a bcm56xxd[1432] 012c0010 Trouble reading stats from interface=1.1 bsx.c2324
Fri May 1 11:50:10 EDT 2009 f5-5110-a bcm56xxd[1432] 012c0007 Trouble creating interface query reply bsx_mcpmsg.c1612
any idea why this si happening
version of bigip is BIG-IP 9.4.7 Build 320.1 Final
- The_Bhattman
Your best bet is to contact F5 support. They can help you isolate the issue.
