Bryce_Klimoski's avatar
Bryce_Klimoski
Jun 11, 2009
HTTP::retry with post data
I have a need to retry web service requests if I receive an http response code other than a 200. The issue that I'm having is that I do not seem to be able to get the post request to work with HTTP::retry.
 when CLIENT_ACCEPTED {
 set Attempts 1
 log local0. "Making attempt $Attempts."
 HTTP::collect [HTTP::header Content-Length]
 set HttpHeaders [HTTP::request]
 log local0. "****************Start HTTP Headers****************"
 log local0. $HttpHeaders
 log local0. "****************End HTTP Headers****************"
 when HTTP_REQUEST_DATA {
 log local0. "echo 1"
 if {$Attempts != 0} {
  HttpRequest is used to retry later on.
 set HttpPostData [HTTP::payload]
 HTTP::release
 log local0. "****************Start Post Data****************"
 log local0. $HttpPostData
 log local0. "****************End Post Data****************"
 when HTTP_RESPONSE {
 if { [HTTP::status] != 200 && $Attempts < [active_members [virtual name]]} {
 incr Attempts
 log local0. "****************Start HTTP RETRY REQUEST****************"
 log local0. "$HttpHeaders$HttpPostData"
 log local0. "****************End HTTP RETRY REQUEST****************"
 HTTP::retry "$HttpHeaders$HttpPostData"
 if {$Attempts >= [active_members [virtual name]]} {log local0. "$Attempts out of [active_members [virtual name]] attempts, no further retries will be made"}
 if {[HTTP::status] == 200} {
 set Attempts 0
 set Attempts 0
However that appears to be only sending the headers accross for some reason. Next I tried this.
  non_200_reselect iRule
  Requires that the default pool name and virtual name match
  History:
  v1.0.0 (2009.03.24 - Bryce Klimoski)
     - Initial Version
  v1.0.1 (2009.06.08 - Bryce Klimoski)
     - Updated to ensure compatibility with both 9.3.1 and 9.4.5
  Uncomment below to enable irule timer statistics
 timing on
 set Attempts 1
 if {Attempts > 1} {
 set length [HTTP::header Content-Length]
 HTTP::payload replace 0 $length $HttpPostData
 HTTP::release
 incr Attempts
 HTTP::retry $HttpHeaders
 set Attempts 0
That ends up giving me the following error in the ltm log.
 - Out of bounds (line 4)     invoked from within "HTTP::payload replace 0 $length $HttpPostData"
Anybody know how this can be done?
  • I tested the following irule and looks like it uses same technique that you use (in your first irule) to retry post request.
    http://devcentral.f5.com/wiki/default.aspx/iRules/HTTP_sideband_policy_checking.html
    part of the irule that relates to this is
    set request_original [HTTP::request][HTTP::payload [HTTP::header Content-Length]]
    and this
    HTTP::retry $request_original
    I wonder if it might work if you save original post request to variable without qoute (")
    set saved_post $HttpHeaders$HttpPostData
    HTTP::retry $saved_post
    or like this
    HTTP::retry $HttpHeaders$HttpPostData
    Nat
