Neil_66348
Nov 12, 2012HTTP::Header insert not working
Hi Guys ,
Can anyone point out why the below might not be working , passing back the below on the response headers to an end users browsers.
No errors okay , just headers don't appear.
clientside {
HTTP::header insert Access-Control-Allow-Credentials true
HTTP::header insert Access-Control-Allow-Origin www.wesbite.com
Neil
- What_Lies_Bene1
I think you should be doing this with the HTTP_RESPONSE event if you want these headers to be sent to the client. - Kevin_Stewart
Employee
The clientside command is about context, not flow. I'm guessing you're seeing these headers show up on the server side?
If you want headers sent to the client, use these HTTP header inserts in the HTTP_RESPONSE.
