tony_haynes_247's avatar
tony_haynes_247
Sep 30, 2011
HTTP::cookie insert not working
version 10.2
This is a very light weight version of my rule. Basically what I need is to set cookie using a source address list.
The matchclass works perfect, but I am not getting any cookies sent to the client.
IE http watch and FF developer tools both show no cookie being sent by the F5.
log local0.info "IP address is [IP::client_addr]"
when HTTP_RESPONSE {
set tmp_IP [IP::client_addr]
log local0.info "$tmp_IP"
if {[matchclass $tmp_IP equals webapp_pilot] }{
HTTP::cookie insert name pcookie value y
log local0.info "match"
HTTP::cookie insert name pcookie value n
log local0.info "no match" } }
  • hoolio's avatar
    hoolio
    Try setting a path in the cookie set:
    HTTP::cookie insert name pcookie value y path /
    And then test with curl:
    curl -v http://1.1.1.1
    Aaron
