Michael_107360's avatar
Dec 10, 2013
HTTP2HTTPS HTTPS/URI issue
When you type in: www.website.xyz you go to: https://www.website.xyz/specific_uri when you type in: www.website.xyz/anotherwebpage you go to: https://www.website.xyz/anyother_uri
This is the Irule on the port 80 virtual server and is working just fine. when HTTP_REQUEST { if {[HTTP::uri] equals "/" } { HTTP::redirect "https://[HTTP::host]/specific_uri" } HTTP::redirect "https://[HTTP::host][HTTP::uri]" }
Issue comes here, I need something on the port 443 virtual server to direct it to the correct uri I can't just add another irule?? How is this possible.
When you type in: https://www.website.xyz you go to: https://www.website.xyz/specific_uri when you type in: https://www.website.xyz/anyother_uri
  • typo....should say when you type in: www.website.xyz/anyother_uri you go to: https://www.website.xyz/anyother_uri
  • Christian_30338's avatar
    Christian_30338
    Historic F5 Account
    hello!
    I am not sure if i fully understand your question. But if you want to use the same iRule on the HTTP and HTTPS virtual server try having a look at the TCP::local_port to see if the request is on port 80 or 443. Should be a simple change. Try something like the following.
         if {[TCP::local_port] == 80} {
          do some port 80 work
          otherwise do some non 80 (443) work
  • If I understand your question, you have a redirect iRule on your port 80 VIP, which should probably look more like this:
    You can then add any iRule you need on your port 443 VIP.
        if { [HTTP::uri] equals "/" } {
