SSHSSH_97332
Aug 08, 2014HTTP URI Parts
http://www.example.com:8080/main/abc/index.jsp?user=test&login=check
In the above , if i want to print second part of URI , which is here "abc" , is this [ [HTTP::uri] 2] or What ?
Yann_Desmarest
Cirrus
Aug 09, 2014As far as I remember, when using getfield with "/" delimiter, your url is cut as follow : /main/abc/index.jsp?user=test&login=check
1 "" <- this is a null string value before the first "/"
2 main
3 abc
4 index.jsp?user=test&login=check
