SSHSSH_97332
Aug 08, 2014HTTP URI Parts
http://www.example.com:8080/main/abc/index.jsp?user=test&login=check
In the above , if i want to print second part of URI , which is here "abc" , is this [ [HTTP::uri] 2] or What ?
Yann_Desmarest
Cirrus
Aug 08, 2014Hello,
You can use this line of codes within irule :
set uri [HTTP::uri]
set stripped_uri [getfield $uri "/" 3]
BR
Yann
