http monitor post
For example: POST HTP/1.1\r\nUser-Agent:tiger_test\r\nHost:[ip:port]\r\nF5Heartbeat:true\r\nConnection:Keep-Alive\r\n\r\n
what's the mean of "nF5Heartbeat:true" ? I don't know what these parameters mean,;
3Q
- Samir_Jha_52506
Noctilucent
This is
HTTP monitor parameter. Its looks like you have hard-coded parameter*not
in monitor POST profile. Run below command on F5 device & paste result..F5Heartbeat:truecurl -vk http://: It's not a parameter nF5Heartbeat:true.
But it's an http header named F5Heartbeat with value true.
By the way, I think that this monitor will fail as several things are missing :
The uri is missing between the method and http version.
HTP -> HTTP.
If you choose to use POST, you must specify a Content-Type and Content-Length headers.
And you must add post data in the body of your request
