Ayrton_Miguel_S's avatar
Ayrton_Miguel_S
Feb 18, 2016
http_class to irule conversion
Does anyone know how to convert a http_class to an irule, the code it's the below.
when HTTP_CLASS_SELECTED { if {[HTTP::class asm] == 1 } {
    if {$disable_asm == 1 } {
        ASM::disable
    else {
        ASM::enable
  • Hi Ayrton Miguel Salazar Cortes,
    you may try the following syntax as a starting point...
        set asm_policy "/Common/YOUR_ASM_POLICY"
        if { $asm_policy ne "" } then {
            ASM::enable $asm_policy
            ASM::disable
    Note: Keep in mind that you have to assign at least one ASM_POLICY (could be a dummy policy) to your Virtual Server to execute the
    [ASM::enable]
    or
    [ASM::disable]
    commands.
    Cheers, Kai
