How works Link controller?
I have 2 ISP connected to one router each one, now the LC is located between the firewall and the ISP routers, but my question is:
in this scenario, who is making the NAT for the LAN request, the firewall or the LC
How many NAT are needed for comunicate the FW with the LC
Some body can give an example of one installation of this kind please
- Whesther_Manuel
Hi Guillermo.
I have this same situation, any recommendation?
Regards.
it has been a long time since i worked with this, but perhaps it can help you.
so something like:
FW - LinkController - rtr isp1 - rtr isp2you can choose yourself which device will do NAT, next to the FW and LC it could also be the ISP router, which might make things easier perhaps. then the LC just has to forward the traffic unmodified.
i don't understand the question on how many NAT you need.
there aren't that many deployment guides for LC i believe, this one shows a rough setup (although also for incoming).
