How to use two ssl profiles depending on connecting address
Morning All,
I'm trying to edit the iapp template.
What I would like to do is implement certificate pinning for all clients except from certain network ranges.
Eg for connections from
134.170.98.0/24
157.56.199.0/24
134.170.70.0/24
Do not require specific certificate on the client device's.
For all other connections require a specific certificate. I know I can add certificate requirement to the ssl profile. I'm guessing I need to create two ssl profiles one with cert pinning and the other without, but a bit lost on how to implement in the irule. Any suggestions?
Existing Irule without changes
Exchange 2013 iRule to select pool without persistence when all Exchange
HTTP-based services are accessed through the same virtual server.
switch -glob -- [string tolower [HTTP::path]] {
"/microsoft-server-activesync*" {
pool /Common/EXO.app/EXO_as_pool7
COMPRESS::disable
CACHE::disable
return
"/owa*" {
return
"/ecp*" {
Exchange Control Panel.
return
"/ews*" {
Exchange Web Services.
pool /Common/EXO.app/EXO_ews_pool7
COMPRESS::disable
CACHE::disable
return
"/oab*" {
Offline Address Book.
persist none
return
"/rpc/rpcproxy.dll*" {
Outlook Anywhere.
COMPRESS::disable
CACHE::disable
return
"/autodiscover*" {
Requests for Autodiscovery information.
pool /Common/EXO.app/EXO_ad_pool7
persist none
return
default {
when HTTP_RESPONSE {
if { ( [HTTP::header exists "WWW-Authenticate"] &&
[string tolower [HTTP::header values "WWW-Authenticate"]] contains "negotiate" ) ||
( [HTTP::header exists "Persistent-Auth"] &&
[string tolower [HTTP::header "Persistent-Auth"]] contains "true" ) } {
ONECONNECT::reuse disable
ONECONNECT::detach disable
NTLM::disable
if {[HTTP::header exists "Transfer-Encoding"]} {
HTTP::payload rechunk
Many Thanks, Andrew.
- stan_piron
Cumulonimbus
you can create 3 VS:
- one routing VS without any SSL and HTTP profile but the next irule
- one VS (same destination address or another one, doesn't matter, never used) with VLAN enabled none. enable first SSL profile
- one VS (same destination address or another one, doesn't matter, never used) with VLAN enabled none. enable second SSL profile
VS1 irule:
when CLIENT_ACCEPTED { if {[IP::addr [IP::remote_addr]/24 equals 134.170.98.0]} { virtual vs2 } elseif {[IP::addr [IP::remote_addr]/24 equals 157.56.199.0]} { virtual vs2 } else {virtual vs3} }if the source IP is too long, you can use a data group list.
