how to use REST API using F5 SDK
The following REST API would pass the Request data for arguments. I am trying to figure out how to the equivalent (pass arguments) the using using the F5 SDK I tried using the update method but I get an error, shown at the bottom
https://{{big_ip_a_mgmt}}/mgmt/tm/asm/policies?ver=12.1.0 Request Data { "fullPath":"/Common/rest-api_12", "active":"true", "virtualServers":[], "enforcementMode": "transparent", "description":"none", "applicationLanguage":"utf-8", "policy-builder":"disabled", "learningMode":"manual", "stagingSettings": { "signatureStaging": true, "placeSignaturesInStaging": false, "enforcementReadinessPeriod": 7 } }
import requests from requests.packages.urllib3.exceptions import InsecureRequestWarning
requests.packages.urllib3.disable_warnings(InsecureRequestWarning)
from import ManagementRoot
mgmt = ManagementRoot("70.60.207.94", "admin", "admin")
p_collections = mgmt.tm.asm.policies_s.get_collection() for p_object in p_collections: policy=mgmt.tm.asm.policies_s.policy.load(id=p_object.id) policy.update(description="bar", learningMode="automatic")
UnsupportedOperation Traceback (most recent call last) /home/jaekim711/f5/test2.py in () 21 print p_object.allowedResponseCodes 22 policy=mgmt.tm.asm.policies_s.policy.load(id=p_object.id) ---> 23 policy.update(description="bar", learningMode="automatic") 24 25
/usr/lib/python2.7/site-packages/f5/bigip/resource.pyc in update(self, **kwargs) 1286 """ 1287 raise UnsupportedOperation( -> 1288 "%s does not support the update method" % self.__class__.__name__ 1289 ) 1290
UnsupportedOperation: Policy does not support the update method
- Jae_Hong_Kim_32
collection = mgmt.tm.asm.get_collection()
for anobject in collection:
print anobjectp_collections = mgmt.tm.asm.policies_s.get_collection() for p_object in p_collections:
print p_object.name print p_object.id print p_object.kind print p_object.selfLink print p_object.allowedResponseCodes policy=mgmt.tm.asm.policies_s.policy.load(id=p_object.id) policy.update(description="bar", learningMode="automatic") - Jae_Hong_Kim_32
[root@localhost f5] ipython test2.py {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} rest-api-07 pwlpR2LJzxplAjAR3lp10g tm:asm:policies:policystate
[400, 401, 404, 407, 417, 503]UnsupportedOperation Traceback (most recent call last) /home/jaekim711/f5/test2.py in () 21 print p_object.allowedResponseCodes 22 policy=mgmt.tm.asm.policies_s.policy.load(id=p_object.id) ---> 23 policy.update(description="bar", learningMode="automatic") 24 25
- Joel_Breton
Hi Jae,
I was able to modify the ASM policy using the modify method - I use Python 3.6 so my code is slightly different
Here's the code I used
from f5.bigip import ManagementRoot bigip = ManagementRoot('ipaddress', 'admin', 'admin') asm = bigip.tm.asm.policies_s for policy in asm.get_collection(): print('Before policy description change: ' + policy.description) print('Before policy description change: ' + policy.learningMode) policy.modify(description='test') policy.modify(learningMode='manual') print('After policy description change: ' + policy.description) print('After policy description change: ' + policy.learningMode)Here's the output of the script the first time it is run
Before policy description change: myasmpolicy Before policy description change: automatic After policy description change: test After policy description change: manualHere's the output of the script the second time it is run - You can notice the values in the policy are now different
Before policy description change: test Before policy description change: manual After policy description change: test After policy description change: manualHope this helps
Also I would advise not to post public IP Addresses on public forums
