Mubasher_Sultan's avatar
Mubasher_Sultan
Jan 14, 2014
How to use Grep command to identify the particular VS and their state?
Hi Folks,
I want to identify the VS servers having the string e.g., TO2 and their "Availability" or "State"
I am using the below command
show /ltm virtual all-properties | grep -i "to2" ---> It works fine... show /ltm virtual all-properties | grep -i to2 | grep Availability ---> Doesn't work show /ltm virtual all-properties | grep -i to2 | grep State ---> Doesn't work
Please help or any advise...
  • grep works on a linefeed boundary, whereas the tmsh output contains multiple lines.
    While you can't do this in tmsh since the grep doesn't support -A there, you could use something like this on the command line:
    tmsh show ltm virtual|grep ^Ltm:: -A5|grep -e 'Ltm::\|\ \ Availability\|\ \ State'
    here's me running that:
    [root@snk-5:Active:Standalone] config  tmsh show ltm virtual|grep ^Ltm:: -A5|grep -e '^Ltm::\|^\ \ Availability\|^\ \ State'
    Ltm::Virtual Server: next4p81
      Availability     : unknown
      State            : enabled
    Ltm::Virtual Server: next4p82
      State            : enabled
    Ltm::Virtual Server: next6p81
      State            : enabled
    Ltm::Virtual Server: next6p82
      State            : enabled
    • Sreenivasa_P's avatar
      Sreenivasa_P
      how to read before and after line like in v10 we have command -a5 or -b5 but its not working in v11
      Sreenivasa_P
      how to read before and after lines like in v10 we have command -a5 or -b5 but its not working in v11
  • That's cool :)
    But, please let me know that how to filter some of the VS having string e.g., "to2" and display as above but not all...
    Regards, Mubasher
  • Substitute where I use ^Ltm:: with "to2" (in both greps) to accomplish that.
    Here's my example where I've modified the grep statements to show only virtuals with "p82" in the name: [root@snk-5:Active:Standalone] config tmsh show ltm virtual|grep p82 -A5|grep -e 'p82|\ \ Availability|\ \ State'
    State : enabled
    State : enabled
