Pavel_71715's avatar
Pavel_71715
Jul 27, 2012
How to send TM Shell command via PowerShell
Hello,
I am quite new in this PowerShell stuff. So sorry for any stupid ideas but really appriciate any tips and tricks from you.
I tried to use this Powershell Snapin (F5 version 11.2) but when I checked the list of possible function I can't find any suitable for sending just simple tmshell strings. It would be for me the easiest way just to send the string with command. I have also dig about the SSH connection via PowerShell and it looked like the easy work but it didn't work for me with F5 for some reason (please see http://vblog.strutt.org.uk/2011/11/...owershell/ ). Thanks for your ideas.
BR,
Pavel
P.S. - updated - I have discovered example how to use iApps (that is great because I can not find good documentation for iApp api)
https://devcentral.f5.com/wiki/iCon...rvice.ashx
