how to send rst to client
hello everyone , I created a virtual server, the type is "reject",I think when client send a request to vs_ip ,F5 send "rst" to client . The expeirment show that F5 no response by capture.Do you know why ?
- Vijay_E
Cirrus
Did you try using a CURL to the VS or telnet to check response ? You can also use the developer tools within a browser like Chrome to identify the response.
Hi yuanqiang,
a
Virtual Server should simply respond with anreject
packet to every connection attempt.TCP-RSTTo troubleshoot your configuration you may try to ping the Virtual IP Address 192.168.20.12 and attach an debugging iRule to your VS to see if you're reaching the Virtual Server.
when CLIENT_ACCEPTED { log local0.debug "Hello World" }Cheers, Kai
